STARTECH USB3S2ESATA3 3 FT. ADAPTER CABLE - 3FT ESATA HARD DRIVE TO USB 3.0 ADAPTER CABLE - SATA 6 GBPS
StarTech USB3S2ESATA3 3 ft. Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Adapter Cable - SATA 6 Gbps Type: SATA III Type: Others Color: Black Connector Number: 2 Connector Detail: Drive Connectors: 1 - eSATA (7 pin; Data) Female Host Connectors: 1 - USB 3.0 A (9 pin; SuperSpeed) Male Speed: 5 Gbps Specifications: Bus Type: USB 3.0 Number of Drives: 1 Drive Type: SATA Chipset ID: ASM1153E Type and Rate: USB 3.0 - 5 Gbit/s UASP Support: No Type and Rate: SATA III (6 Gbps) Port Multiplier: No Max Drive Capacity: Currently tested with up to 4TB 7200 RPM hard drives Hot Swap Capability: Yes Electrical Outlet Plug Type: Plug Type “A� (USA, Canada, Mexico, Japan)
Price: 27.49
